| Posted by Joe B on January 06, 1999 at 14:23:33: | |
I'm installing a new Mustee shower pan and walls. The old pan and walls were in bad shape. When I removed the old pan, I noticed that the pan was only connected to the 2" p-trap waste drain by a rubber sleeve. The new pan also has a rubber sleeve to connect up the drain. Is that all there is? Are there any special trick or tip on installing the sleeve to ensure a good seal and no leaks. Would appricate help before I turn on the H20. Thanks |
