| Posted by rick on April 13, 2002 at 09:09:22: | |
| In response to Re: what to use to set shower base on basement floor a little uneven | |
: : Purchased a base, came with a drain, but no instructions. The drain has black rubber gasket. Does this gasket go on top or bottom side of base? Thank you very much. : The rubber gasket goes under the shower pan, then the fiber friction washer, then nut. On the top side of the pan, you can use Silicone on the flange of the drain. Terry
| There are none. |
