Re: Kohler Pressure Clear Flushometer
Posted by Marc on April 01, 2002 at 13:16:59:
In response to Re: Kohler Pressure Clear Flushometer
I have the same problem with mine - what was the problem and how much did it cost to fix?
Thanks
b: I've got the same problem with my 81100. What did you have to do with yours to correct the problem? Thanks ... Ken
: : That model number may not be accurate. Kohler numbers are usually K-XXXX, a K followed by a four digit number. If this is a recently manufactured toilet, it may have the Sloan Flushmate in it, in which case you can go to their Web site at www.flushmate.com for instructions in repair and maintenance. If it's an earlier Kohler with their own system, you may have to contact Kohler directly (www.boldlookofkohler.com).
: : : Has anyone ever worked on one of these? My specific model is the Kohler 81100, and it's one of those pressure cannister flushers. It's lost a lot of its oomph in the flush.
: : : What causes this? Are the parts still available to fix it? Thanks.
Replies to this post
There are none.
