Re: Tub overflow drain leaking
Posted by Lou on January 03, 1999 at 23:21:51:
In response to Re: Tub overflow drain leaking
Are you sure it is the overflow that is leaking. I have seen it leak where the pipe leading to the tub spout is not sealed with silicone. Remove the spout and check to see that hole around pipe feeding spout is sealed, don't apply silicone around the spout it looks ugly. While you are there you could add a little silicone to the fibreglass side of the overflow gasket and let set up. Also try and see if you can shim up your tub with something to support the weight. And finally redo your waste connection with putty, making sure it is tight.
Best of Luck....Lou
Replies to this post
There are none.
