Re: upstairs bathroom mess
Posted by Lou on January 03, 1999 at 23:13:17:
In response to Re: upstairs bathroom mess
Are you living in an area of hard water. If so I have seen calcium deposits plug up the siphon jet hole (the small one in the bowl) so bad in the space of two years that the water closet was rendered almost useless. If this is the problem make sure you clean out the wash down jets on underside of water closet top lip also. I use a close hanger, alight mixture of muriatic acid works too, but you run the risk of ruining the bowl.
On the tub it might be one of the two drain connections, the overflow (easy) or the p&o (harder).
Best of luck.....Lou
Replies to this post
There are none.
