Re: leak at toilet flange
Posted by Lou on January 03, 1999 at 22:39:18:
In response to Re: leak at toilet flange
Two wax seals might be too much and cause a blockage at the floor flange which should be at least level with the finished floor. Seals with horns I tend to find add restriction to the discharge of the water closet. What I use is a seal and a half, your hands get all messed up fooling with the half seal making it round, but it works for me. Also check and make sure that your flange extensions are sealed also. Applying a light coat of wax seal with your finger to the joints in the extentions will help here. Best of Luck......Lou
Replies to this post
There are none. |
