| Posted by Bud..Suncoast Plumbing Inc. on January 03, 1999 at 22:17:29: | |
| In response to Re: pressure valve on waterheater continues to leak. | |
: pressure valve on waterheater leaking,replace valve : with standard valve(150psi)but valve continues to leak. : after shower or bath while heating up fresh water is when water valve leaks.why is the tank building up to much pressure? or is it? it began aprox. 2 months ago, : been keeping track of water flow. also cut temp. back to 125 deg. to see if getting to hot. water pressure does not seem to have increased. is this were my problems is? ........... can you help? p.underwood
| There are none. |
