Re: What's considered "Water-Resistant Wall Material" now?
Posted by savoy on January 03, 1999 at 00:12:02:
In response to Re: What's considered "Water-Resistant Wall Material" now?
: I am installing a Kohler Sonata Acrylic shower module by myself. The instructions specify installing "Water-Resistant Wall Material" next to the enclosure.
: Am I okay to just install green-gypsum-wallboard and paint this, or install the newer concrete "wonder board" types and tile over this? How does painting over "wonder board" look?
: Also, what material should be placed on the outside stud walls surrounding the enclosure? Someone suggested this interior would encourage the growth of mildew and mold because the acrylic surface might sweat due the the different building materials used for framing and finishing? True or false?
: Any other suggestions?
: Dennis
Dennis, greenboard is fine for this. Cement board should be used where water will be ie behind tile. you have the enclosure protecting the board. Good luck.. Savoy
Replies to this post
There are none.
