| Posted by Nancy Stevens on March 23, 2002 at 14:40:50: | |
| In response to Re: Faucet in tub and shower. I get to much hot water and not enough cold water. I need to know how to adjust. | |
: : I have to keep the hot water heater turned down so not to get burned by the hot water. I'm told there is a cold water mixer located somewhere in my faucet. I need to know what it looks like and how to adjust it. Is it easy to replace if it needs to be replaced and is it expensive? : : Thank you. : Teresa, We need to know what brand of faucet you have to help, is there a name on the faucet? : Scott I'm not Theresa, but I have the same problem--- mine is a MOEN and I have the whole thing apart from the front, mine appears to be hard soldered in copper pipes too? what do I do? i thought it would look obvious when I took it apart, but it isn't. Help
| There are none. |
