| Posted by Steve kelly on March 18, 2002 at 15:56:47: | |
| In response to Re: Bathroom Remodle | |
I put in a Jacuzi tub and am happy with it. It runs well. It is a little hard to keep clean. I also tiled above and brought the drywall down to the lip of the tub but don't put the drywall or tile down so it istouching the tub. You nee to leave a little gap and fill in wit caulk so the water does not wick up. Another mistake i made was when I put te sealer on the grout. It ran down into the tub and I did not remove and rinse quick enough and it left streaks. : I am remodling my bath and I am laying tile flooring and putting in a whirlpool tub. What are some of the better tubs? Where does the access panel need to be on a skirted tub? do I lay the tile flooring befor or after I put in the tub? I also want to know about tiling the tub wall... Does the corners need corner beeds and taped and smoothed out or can I just put up the sheetrock and start to tile when the bathtub is in place.
| There are none. |
