| Posted by Terry Love on January 01, 1999 at 17:17:32: | |
| In response to Re: Water Pressure | |
Dear Wayne, You should be able to adjust the switch settings on your pump. 15-40 is a bit low. You may want to go with 30-50, or even bump it up a bit higher. Some pumps are running in the 40-60 PSI range. I would check with the water treatment people. It may be internal parts. Best regards, : Dear Terry, : My house is in the country on a drilled well in the wilds of Nova Scotia, Canada. The water pump is a 1/3 H.P. unit with a pressure tank. The pump cuts out at 40 psi and starts at 15. I have 2 water treatment systems for extremely high iron content. There is not enough water pressure to run the water treatment systems and I don't know if I should incur the expense of a plumber or should call the water treatment people. I know it's impossible for you to say, but who would you recommend that I call? I hate to pay for a plumber to come out to tell me it's a water treatment problem and vise versa. I do not believe that the pressure tank is flooded (I can't hear any water slosh when I move it), but the high rust content has frozen the drain valve. : I trust that you have enjoyed a good holiday with your family. Your assistance in this matter is appreciated. : Kind regards,
