Re: Hydrostatic pumps
Posted by hj on December 31, 1998 at 00:28:06:
In response to Re: Hydrostatic pumps
No safe way, because it is beyond the safe pressure for air compressors or CO2 pressurization. Pump may be available for rent.
: Vanex Pex local codes requires 200psi pressure.
: Hydrostatic test pump is $325+. Do you know another
: method to obtain this pressure. I used a pressure
: washer once {quite dangerous}.
Replies to this post
There are none.
