| Posted by J bassett on December 29, 1998 at 22:17:58: | |
The overflow drain leaks whenever someone takes a shower. I've replaced the washer between the tub(fiberglass) and the overflow drain pipe - but it still leaks. The leak is worse when a heavier person uses the shower. Is some sort of sealant required, to be used with the washer? Shouldn't tightening the cap seal the tub and the drain? |
