| Posted by Mike Angelo on December 29, 1998 at 18:32:33: | |
| In response to Re: water heater | |
Just an idea...but I have found a similiar problem, but I (as you may be doing) had closed off the water supply coming into the hot water heater. By opening the supply valve while the drain is opened did force out the sediment (if it's not too much and you have good water pressure it may work for you too)... otherwise, I would try poking a small wire into the drain valve (such as a brazing rod or coat hanger wire) to see if you can break free the clog, or at least get some of it flowing.... ...good luck. Mike
| There are none. |
