| Posted by mike on March 04, 2002 at 23:35:33: | |
| In response to Re: Specs for Irragation system pump | |
: Curt, Did you complete this project yet? I am curious as to the outcome. I am looking at doing a similar system. : Thanks, : : : : You should design the lawn irrigation system first and then provide a pump that will supply its needs. While designing it, you should also consider the potential pumps that are available within your budget. It is sort of a catch 22, since one will affect the other. : : : : Anyone have some suggestions for a pump for an lawn irragation system. I would like to pump out of my pond. I don't need much suction lift. I have approximately 3600 sq ft of lawn. I would like to know typical gpm and pressure requirements for a lawn sprinkler system. : : : : Thanks in aadvance. : : : : -Curt
| There are none. |
