| Posted by hj on December 27, 1998 at 23:05:58: | |
| In response to Re: bathtub replacement | |
A good plumber who does remodeling would have no problems removing the tub, but it is not something I would recommend for a DIY'er as a first time project. It takes a certain amount of experience to get the tub out, the new one in, and connecting the drain, without major damage to the existing walls. : I recently purchased an older home (built ~1960) the place needs LOTS of work. The present bathtub can't be salvaged, and must be replaced. I have not taken posession yet, so am not sure of everything I am in for. What holds the bath tub in place?? What do I need to do to remove it?? Any framing involved?? It appears to be a cast iron, and is flush to the walls on 3 sides. There doesn't appear to be any special framing around the tub, it is just flush with the walls of the room. : Thanks
| There are none. |
