Re: leak in shower stall
Posted by v.j.ssf on December 20, 1998 at 05:05:08:
In response to Re: leak in shower stall
: I would use a good quality Silicone caulk on the corners. Also check the door sweep, to see if water is splashing out under the door.
You may have to take out the whole glass enclosure and caulk\recaulk underneath the ENDS of the bottom rails.
Good luck.
Replies to this post
There are none.
