Re: toilet leak outside at refill valve
Posted by v.j. ssf on December 20, 1998 at 04:38:05:
In response to Re: toilet leak outside at refill valve
: My toilet leaks sometimes after it's flushed, on the underside of the tank by the refil valve. To stop the leaking, I've had to tighten the water shut-off valve to the tank. I loosen it everytime after flushing so the tank can fill up. Do I need to replace the refill valve, or does it sound more like a rusted bolt on the underside of the tank? Thanks It sounds like the problem is at the connection between the tank and the bowl. Try a new gasket, and while you're at it ,if the bolts look rusted, change them
Replies to this post
There are none. |
