| Posted by Randy Mosley on February 05, 2002 at 16:40:35: | |
| In response to Daisymosley@hotmail.com | |
: : We are remodelling our bathroom. Currently there is vinyl flooring with pressed board underneath. : : We will be installing tile on the floor and are wondering if we can just put pressed board down again or : : do we need to put down wonder board. Is the wonder board necessary to spend the extra money vs the : : pressed board? Also, what are your thoughts on wonder board vs. green board for the walls common to : : the shower which will be tiled. Thanks for your help. : Tile can be installed over the vinyl, or you can use ACX plywood or wonderboard, but not pressed board. Particle board will expand when wet and pop the tile. : For the walls, go with the wonderboard.
| There are none. |
