Re: slow tub drain, toilet gurgles
Posted by dave on December 19, 1998 at 10:34:43:
In response to Re: slow tub drain, toilet gurgles
:If this is something that just has arisen it and you have a septic system it could be a minor problem. I had the same symptoms and then a "clog". I went outside and opened the inspection port (a 6-8 inch PVC pipe) I noted that the waste fom the house was clogging up with tissue at the point of entry into the tank. I dislodged the clog with a broom handle just fine. Since then we changed our toilet tissue to one of less of a ply rating and haven't had a problem since. THX.
Replies to this post
There are none. |
