Re: pex tubing
Posted by hj on December 19, 1998 at 00:07:06:
In response to Re: pex tubing
If you have PEX, then you do not have to be concerned about PB or its manufacturer. It is not installed with a manifold system, that was a PB invention. The buyer is protected by the UCC codes, unless there is something like the PB class action settlement to change it.
: I have discovered that my new home is plumbed with pex tubing.
: I understand that pex is better than pb.?
: Is there code that says you should have a manifold system? I do not have. Who protects the buyer?
: I have VANEX and QEST-f;vanguard makes the first but who manufactures qest. US Brass? I understand that they are going belly-up. Did the plumber use old material?
Replies to this post
There are none.
