: : I need to run a stretch of gas line in my garage for : : a gas dryer. There is already gas in the garage for : : the central heat and the dryer is only located about : : six or seven feet away. The furnace is fed by black : : pipe coming into the garage with a shutoff valve : : to which is connected the flex tubing going to the : : furnace. : : My question is, if I connect a tee downstream of the : : valve and run a stretch of flex tubing over to the : : gas dryer (I'll add an additional shutoff valve : : just before going into the dryer) will I get enough : : flow rate for the furnace and the dryer to run : : properly? Or, should I put a tee in the black pipe : : and run black pipe over to the dryer followed by a : : shutoff valve just before the dryer? : : I appreciate any suggestions here..... : 121 0.0 Material For Gas Piping : 1210.1 All Pipe Used For The Installation, Extension, Alteration, Or Repair Of : Any Gas Piping Shall Be Standard Weight Wrought Iron Or Steel (Galvanized : Or Black) Or Yellow Brass (Containing Not More Than Seventy-Five (75) Percent : Copper). Approved Pe Pipe May Be Used In Exterior Buried Piping Systems. : 1210.2 All Such Pipe Shall Be Either New, Or Shall Previously Have Been : Used For No Other Purpose Than Conveying Gas; It Shall Be In Good Condition : And Free From Internal Obstructions. Burred Ends Shall Be Reamed To The Full : Bore Of The Pipe. : 1210.3 All Fittings Used In Connection With The Above Piping Shall Be Of : Malleable Iron, Yellow Brass (Containing Not More Than Seventy-Five (75) : Percent Copper), Or Approved Plastic Fittings. : 1210.4 All Valves And Appurtenances Used In Connection With The : Above Piping Shall Be Of A Type Designed And Approved For Use With Fuel : An Accessible Shutoff Valve Of A Type Set Forth In Section : 1211.13,Shall Be Installed In The Fuel Supply Piping Outside Of Each : Appliance And Ahead Of The Union Connection Thereto, And In Addition To : Any Valve On The Appliance. Shutoff Valves Shall Be Within Three (3) Feet : Of The Appliance. Shutoff Valves May Be Located Immediately Adjacent : To And Inside Or Under An Appliance When Placed In An Accessible And : Protected Location And When Such Appliance May Be Removed Without Removal : Of The Valve. Shutoff Valves May Be Accessibly Located Inside Wall : Heaters And Wall Furnaces Listed For Recessed Installation Where Necessary : Maintenance Can Be Performed Without Removal Of The Shutoff Valve. : 1) Listed Metal Appliance Connectors Shall Have An Overall Length : Of Not To Exceed Three (3) Feet Except A Range Or Dryer Connector, : Which May Not Exceed Six (6) Feet . : (2) No Part Of Such Connector Shall Be Concealed Within Or Extended : Through Any Wall, Floor, Partition, Or Appliance Housing : Demand In : Appliance Btu/H Watts/H : Barbecue (Residential).. 50,000 14,050 : Bunsen Burner................ 3,000 879 : Domestic Clothesdryer........ 35,000 10,255 35,0132 : Domestic Gas Range......... 65,000 19,045 : Domestic Recessed Oven Section........ 25,000 7,325 : Domestic Recessed Top Burner Section......... 40,000 11,720 : Fireplace Log Lighter (Commercial)........ 50,000 14,650 : Fireplace Log Lighter (Residential).......... 25,000 7,325 : Gas Engines (Per Horsepower)........... 10,000 2,930 : Gas Refrigerator.................. 3,000 879 : Mobile Homes (See Appendix E) : Steam Boilers(Per Horsepower)................ 50,000 14,650 : Storage Water Heater : Up To 30 Gallon (114l)....................... 30,000 8,790 : Storage Water Heater : 40 (151 L) To 50 Gallon (189 L) Tank... 50,000 14,650 : Table 12-2 : Support Of Piping : Size Of Pipe : Table 12-3 Gas Meter : Size Of Gas Piping : Maximum Delivery Capacity Of Cubic Feet Of Gas Per Hour Of Ips Pipe Carrying : Range Natural Gas Of 0.60 Specific Gravity Based On Pressure Drop Of 0.5 Inch : Water Column : Pipe Size Length In Feet : Inches, : Feet>>>> 10' 20' 30' 40' 50' 60' 70' 80' 90' 100' 125' : 1/2 174 119 96 82 73 66 61 56 53 50 44 : 3/4 363 249 200 171 152 138 127 118 111 104 93 : 1 684 470 377 323 286 259 239 222 208 197 174 : 1-1/4 1404 965 775 663 588 532 490 456 428 404 358 : 1217.0 Required Gas Piping Size : 1217.1 Where The Maximum Demand Does Not Exceed Two Hundred Fifty : (250) Cubic Feet Per Hour (2 L/Sec.) And The Maximum Length Of Piping : Between The Meter And The Most Distant Outlet Is Not Over Two Hundred Fifty : (250) Feet (76 M), The Size Of Each Section And Each Outlet Of Any System Of Gas : Piping Shall Be Determined By Means Of Table 12-3. Other Systems Within : The Range Of Table 12-3 May Be Sized From That Table Or By Means Of The : Methods Set Forth In Section 1217.3. : 1217.2 To Determine The Size Of Each Section Of Pipe In Any System Within : The Range Of Table 12-3, Proceed As Follows: : (1) Measure The Length Of The Pipe From The Gas Meter Location To The : Most Remote Outlet On The System. : (2) In Table 12-3 Select The Column Showing That Distance, Or The Next : Longer Distance If The Table Does Not Give The Exact Length. : (3) Starting At The Most Remote Outlet, Find In The Vertical Column Just : Selected The Gas Demand For That Outlet. If The Exact Figure Of Demand Is : Not Shown, Choose The Next Larger Figure Below In The Column. : (4) Opposite This Demand Figure, In The First Column At The Left In Table : 12-3 Will Be Found The Correct Size Of Pipe. : Fuel Piping 1217.2 - 1218.4 : (5) Using This Same Vertical Column, Proceed In A Similar Manner For : Each Section Of Pipe Serving This Outlet. For Each Section Of Pipe, : Determine The Total Gas Demand Supplied By That Section. Where Gas : Piping Sections Serve Both Heating And Cooling Equipment And The : Installation Prevents Both Units From Operating Simultaneously, Only The : Larger Of The Two Demand Loads Need Be Used In Sizing These Sections. : (6) Size Each Section Of Branch Piping Not Previously Sized By : Measuring The Distance From The Gas Meter Location To The Most Remote : Outlet In That Branch And Follow The Procedures Of Steps 2, 3, 4, And 5 : Above. : Note: Size Branch Piping In The Order Of Their Distance From The Meter : Location, Beginning With The Most Distant Outlet Not Previously Sized. : 1217.3 For Conditions Other Than Those Covered By Section 1217.1, Such As : Longer Runs Or Greater Gas Demands, The Size Of Each Gas Piping System Shall : Be Determined By Standard Engineering Methods Acceptable To The : Administrative Authority And Each Such System Shall Be So Designed That : The Total Pressure Drop Between The Meter Or Other Point Of Supply And Any : Outlet When Full Demand Is Being Supplied To All Outlets, Will At No Time : Exceed Five-Tenths (0.5) Inches (12.7 Mm) Water Column Pressure. : 1217.4 Where The Gas Pressure May Be Higher Than Fourteen (14) Inches : (355.6 Mm) Or Lower Than Six (6) Inches Of Water Column, Or : When Diversity Demand Factors Are Used, The Design, Pipe, Sizing, Materials, : Location, And Use Of Such Systems First Shall Be Approved By The : Administrative Authority. Piping Systems Designed For Pressures Higher : Than The Serving Gas Supplier'S Standard Delivery Pressure Shall Have Prior : Verification From The Gas Supplier Of The Availability Of The Design Pressure. : Systems Using Undiluted Liquefied Petroleum Gas May Be Sized Using Table : 12-7 For Eleven (11) Inches (279.4 Mm) Water Column And In Accordance With : The Provisions Of Sections 1217.1 And 1217.2.
