Re: Freezeproof Sillcock Repair
Posted by j hagen on January 13, 2002 at 12:10:48:
In response to Re: Freezeproof Sillcock Repair
: You should be able to access the washer from outside. Remove the handle, then the packing nut, the stem should then screw out. The stem is as long as your frostproof sillcock, allowing easy access to the washer. The seat on the other hand is another story.....Lou
However, if you are in a hard water area, the stem may be "frozen" with deposits and may not come out so easy. Jim
Replies to this post
There are none.
