Re: water heater relief valve
Posted by Brunswick on January 06, 2002 at 14:43:29:
In response to Re: water heater relief valve
: : : I have the same problem,I have replaced my water heater relief valve 3 times for the past two months and the problem is still there. I hope someone can answer and solve the dilema! Your water pressure may be surging beyond the limit of the relief valve. Thus your valve is working properly. In some municipalities the water pressure fluctates, often overnight. The city sometimes will not admit to this. Get a pan or drain to catch the water. Good luck!
Replies to this post
There are none. |
