I spent New Year's Eve working on replacing some galvanized fittings that some idiot had put on my copper plumbing (not a pretty picture--yucky corrosion!) and wanted to share a tip. Despite all my attempts to drain the copper pipe, water still came from somewhere. Finally I got out my little wet-dry vacuum and sucked a couple of gallons out of the pipe. Voila! The vacuum hose fit over the 1/2" brass fitting just tightly enough to create suction. If it hadn't, I might have tried a sock or a bunch of teflon tape.
