Re: Shower drain
Posted by hj on December 11, 1998 at 00:54:06:
In response to Re: Shower drain
If you do not clamp it, the liner will be useless as a leak deterent. Replace it with the proper type.
: I've got a 1957 iron shower drain in a slab. Can I use a vinyl pan liner if the drain won't "clamp." Would I need to drill weep-holes?
: Thanx
Replies to this post
There are none.
