| Posted by Jim Cooper on January 01, 2002 at 12:43:25: | |
| In response to Re: Hot water heater problems | |
: I have no knowledge about waterheaters. The copper tube that comes from the top of the tank and down the side of the tank keeps leaking on and off. Can you tell me why?
Before beginning replacement turn water heater off and drain some water from water heater, via hot water from faucetts. NOTE: If hot water remains in water heater it will pressurize the tank. That hot water will blow out was you remove the |
| There are none. |
