Re: shower seat question
Posted by Lloyd on December 06, 2001 at 12:14:05:
In response to Re: shower seat question
OK - I have a pretty basic question. I'm also installing a shower seat and need to know how high I should make it. Is
there a standard? Also, I'm planning on creating a pan for the seat but was planning on durock, then 40 mm liner, then
thinset and tile for the front of the seat. Is that right? Thanks for the help.
: Following is an earlier question. (I didn't know how old they get before they quit getting looked at for additional commentary)
: The question now is:
: So I build the seat, durock it for stability, then cover it with liner, of course adhering all seams, and up the walls.
: Now, I'll be trying to adhere a relatively thick layer of deck mud to the vertical and horizontal surfaces of the
: seat. Yuck. How about instead of that, using a mastic to affix another layer of durock, then filling the joints, and
: tiling over that?
: Thanks very much for your help.
: In Reply to: shower posted by stephen on July 25, 19100 at 10:05:21:
: : I'll be building a tile shower, and want to know how to build the seat. I know I need to continue the pan behind
: : where the seat will be, but that seems as though it will leave the wood framing for the seat sitting on theoretically
: : saturated concrete. Should I basically encapsulate the seat itself in pan membrane, and then float it, like I
: : will for the dam?
: : Thanks for your help.
: : Stephen.
: You've got a pretty good mind! You are right, the pan covers the total bottom floor area, and then the constructed seat also needs a pan or splash pan or
: membrane extending eighteen inches up the wall behind grout and tile, in front of the durock or hard board or green sheet rock, and then bending at the seat to
: cover the framing and durock or hard board, and then bending again at the knees to fall into the shower pan. Then the thinset and tile and grout and sealer go on
: top of that. Remember to slope the seat 2 percent (seat to knees) to drain the water from it when the shower quits
OK - I have a pretty basic question. I'm also installing a shower seat and need to know how high I should make it. Is there a standard? Also, I'm planning on creating a pan for the seat but was planning on durock, then 40 mm liner, then thinset and tile for the front of the seat. Is that right?
Replies to this post
There are none.
