Re: Water Softener Blockage
Posted by seder on December 06, 2001 at 12:03:32:
In response to Re: Water Softener Blockage
: : I have a Culligan Mark 89 water softener. It has recently stopped producing soft water. Upon checking inside the brine tank,the water has risen up to the float valve shutoff level. When a recharge cycle, nothing occurs when it should be backwashing water from the brine tank. The only sounds I hear are the rapid rinse and brine tank refilling cycles. So, there must be a blockage within the brine tank. What could it be the problem and how do I correct it?
Replies to this post
There are none. |
