Re: slow tub drain, toilet gurgles
Posted by hj on December 06, 1998 at 10:33:11:
In response to Re: slow tub drain, toilet gurgles
Without the verbosity, you have a restricted main drain from that bathroom and most likely the entire residence. Contact a plumber to rod it out and the problem should be cured it there is no physical problem with the piping.Bad vVenting is seldom an actual problem in a properly working system.
: Terry,I have a house w/ one bathroom. When the tub drains, it is very slow. As the tub drains,the toilet will gurgle and bubble. Gurgling can be heard from the clothes washer drain pipe as well. Lastly, after the toilet is flushed, it refills to its normal level and then all the water drains out of the bowl. All these fixtures are in the same bathroom. Is this a venting issue? If so, how can I fix it?
: Thanks,
: dana s
: Bellingham, WA
Replies to this post
There are none.
