| Posted by sarahduchess on November 20, 2001 at 18:45:31: | |
| In response to Re: garbage disposal turns but double sink filling with water | |
: : I have a double sink in my kitchen. When I use the side that is attached to the disposal, water backs up on both sides of the sink. I have to turn on the disposal and eventually the water clears out of both sides. The disposal is turning and it does grind up : : food that is put into it. Is this a disposal problem or is there a snake living in my drain further on down the line? Or...??? I did take apart the trap under the sinks and it was clear as were the pipes going to and from it. : : Any insight is greatly appreciated. : : thanks,
| There are none. |
