| Posted by Peter Watts on December 02, 1998 at 00:56:09: | |
| In response to Re: wonderboard | |
: What is the easiest way to cut wonderboard? It says to score and snap, but what do you score it with. : How about making holes? There's an intentional tool for @ $5 with a carbide tip that should be available at home-center type places, but for a small job you could sharpen one corner of an old screwdriver, use a scratch awl, anything steel you can get accuracy with along a board straightedge. For holes, a holesaw drillbit mandrel with changeable hole-thangs in different sizes, also available at the amateur level. Cometa think of it, pick up an amateur level while you're there... |
| There are none. |
