| Posted by hj on December 01, 1998 at 07:30:45: | |
| In response to Re: Basement floor drain | |
Normally that drain should be attached to the sump pump basin, so if it overflows the drain would also overflow. To remove the debris, try a shop vacuum, you may have to use a screwdriver or other item to loosen the debris. : We have a floor drain next to the sump pump sump area. We assume it is for an overflow should the : When the builders completedthe house they must have allowed debis such as nails, small rocks or : Can you tell us how this debris can be removed? : Do some of the professional drain cleaners have equipment to attack these kinds of problems?
| There are none. |
