| Posted by hj on December 01, 1998 at 07:27:35: | |
| In response to Re: gerber Ultraflush | |
Almost any usable water pressure will operate the toildt. The water pressure is compressing an air bubble which is creating the pressure, so as long as the air is in the tank, it will compress tothe line pressure and flush properly. : Any problem with minimum pressure with this power assisted toilet? I am rewoking a 2nd story bathroom with a well - jet pump in the basement and minimum system pressure of ~30psi measured at the pump. So 2 stories up it will be close to 20 psi minimum???
| There are none. |
