| Posted by Larry Guyton on October 13, 2001 at 17:48:03: | |
| In response to Re: How do i replace old screws in floor for toilet?? | |
: If you do not have an attachment flange on the pipe then the correct way is to break the concrete around the pipe and attach a flange to the pipe. If you have a flange but it has rusted away, then you can either remove it and install a new one, or get a two piece flange that will fit around your plastic pipe. : : When we took the old toilet out, the screws came out, we are installing a new toilet and need to know how to put new screw in? thank you!!
| There are none. |
