Installing a Galbocca Whirlpool
Posted by Ed Clarke on November 25, 1998 at 19:07:47:
I am installing this tub in my basement, Galbocca corner unit. I have the floor all broken for the drain to go the main drain. The problem that i have is this tub is finished on both front sides, the access is in the back walls, the drain hole in the tub is in the front. How do i install all the plumming, drain and overflow, on the tub plus the pluming going to the main drain. Plus the plumming needs to be covered back in with cement again, how do i hook the drain up from the tub to the floor. Any ideas is appreciated.
Replies to this post
There are none. |
