| Posted by KULDIP LEGHA on September 19, 2001 at 17:43:31: | |
| In response to Re: Shower Pan Installation | |
: I have jsut removed the tiles from the shower floor and found out there is no drain pan. What should I do before I install new tiles. or are there shower pans raised enough to have the plumbing (drain) above the slab and then run the drain out the lower garage wall and into the ground?
| There are none. |
