| Posted by Bud..Suncoast Plumbing Inc. on November 24, 1998 at 20:19:53: | |
| In response to Re: Gas and Water pipe installation | |
Gene:--If I were going to do this work for my self, I think I would use a 1" diameter Poly pipe for the water service (similar to what the water dept. is using..usually color coded blue). For the gas line, I think I would go for the new 3/4" csst offering (Corrugated stainless steel tubing) like Trac-Pipe or similar type. The additional 100,000 BTUs might strain the capacity of your house piping, if possible, run the new gas line to the meter location and tee off at that point for your new construction project. Lots of luck...Bud. I am building a garage and is located approx.
| There are none. |
