| Posted by hj on November 23, 1998 at 23:51:53: | |
| In response to Re: Diaphragm Washers in Compression Faucets | |
That is the Aquaseal unit which I mentioned, and there is only one size. : : I have absolutely no idea what he is talking about. A diaphragm is a thin material that flexes in response to pressure changes. There are no faucets that have that on the stems. The closest is the American Standard Aquaseal, which has an expanding rubber piece to turn off the waterl. : : : I am wondering if there are different sizes of diaphragm washers used in compression faucets. I'm talking about the type of "washer-like diaphragm that covers the bottom of the stem." Quote from "Do Your Own Plumbing", by K.E. Armpriester. Thank you. : I'm talking about the little washers that are made of soft black rubber which look like top-hats, and which fit over a little flat metal protruding disc at the end of the stem. I'm wondering if there are different sizes of these.
| There are none. |
