| Posted by hj on November 22, 1998 at 22:49:31: | |
| In response to Re: reverse osmosis water system | |
Shut off the system, and open the faucet to let all the water drain out. Then keep the faucet open and check the air pressure with a tire gauge. If it is not about 15 pounds, use a tire pump to add air. This will force water out of the faucet so do not turn off the faucet while pumping air into the tank.
: Daryl Groen
| There are none. |
