Re: toilet overflows
Posted by Beatrice on November 20, 1998 at 22:06:23:
In response to Re: toilet overflows
T: Bea,
: Remove the toilet to the outdoors and look inside the lower portion of the toilet, where the waste comes out. Sometimes things like combs, toys, and small bottles will lodge in there and prevent it from working like it should. If this is the case, you can remove the offending little critters and reinstall the toilet. But Wait! There's more! Do you want to put that old toilet back anyway? Is this your chance to install a really fine elongated toilet that will make all the men in your house as happy as when they put the lid down for you? Check it out!
Thanks, Terry. I really appreciate your help on this. I'll try the clean-out first. May just replace the old toilet with a spiffy new one per your suggestion. Bea
Replies to this post
There are none.
