Posted by nigel on August 14, 2001 at 20:52:21:
In Reply to: Re: Bathroom Sink Smell posted by Robert Davis on November 04, 19100 at 14:42:57:
: : It is not the installation that has the problem it is the sink. Pour a drain cleaner such as Liquid Plummer down to overflow hole to burn out the debris that has accumulated.
: : : We recently installed a new corian sink. We had a plumber do it, but found out he was not licensed.
: : : After using the sink for about a month, I noticed
: : : a smell coming from the trap when I run the water.
: : : Sometimes the smell is stronger than others and I can
: : : temporarily eliminate if I spray Windex down the trap
: : : and then run the water until it overflows into the
: : : trap to rinse the Windex.
: : : Obviously this upsets me since it is a new sink and
: : : we have not other water problems. What advice can you
: : : give. Thank you , Jennifer
