| Posted by Don Webb on August 14, 2001 at 15:32:12: | |
| In response to Woodford Faucet Repair | |
Following worked for me: 1. Used hose end fitting to seal off faucet 2. turned on water in faucet and slowly backed out packing gland nut to let water pressure force out packing. 3. shut off water supply to faucet and removed stem. 4. Replaced washer and lubricated all parts with Harvey's Plumber Faucet and Valve Grease. 5. replace packing gland during re-assembly. SECRET: Use water pressure to force out packing gland!!! Lubricant makes faucet operate easier. Parts are available at plumbing supply store, you need washer and packing at a minimum. |
| There are none. |
