Re: Basement Toilet
Posted by hj on November 20, 1998 at 00:32:22:
In response to Re: Basement Toilet
They do not flush up, they just flush above the floor. You need an ejector pump and molded plastic basin. The shower and sink will also drain into it.
: I need info/advice on installing a toilet on a concrete basement floor. I've heard that a flush
: up style mounts on the floor and the mechanics are behind and mounted in the stud wall. What dimensions are needed for stubbing, does the drain
: connect to the exsisting waste line? I'm concerned that theres not enough flush to reach the waste line that is approximately 7 ft. above the basement floor. Also, how do I drain the sink and
: shower.
: Any advice would be much appreciated.
Replies to this post
There are none.
