| Posted by William B Murray on August 08, 2001 at 19:47:16: | |
| In response to Re: Water Pressure | |
: My Lawn sprinkler repairman told me to call the water co. in response to what he considers low water pressure in my home : (the sprinklers were dribbling ). The water company came and agreed that the pressure at the house was about 40psi, where : is should of been about 60psi...The water co guy checked at the connection on the sidewalk in front of my house and said that : it was normal coming into my pipes... He said to consult with a plumber... His readings ( and I can't : verify them) are STATIC 60PSI,,RESIDULE 35PSI AND either CPM OR EPM-- 28PSI...The distance from : the sidewalk to my house is about 75 feet... He also mentioned that we are using a 5/8 inch pipe in the : house, whereas the meter is one inch...whatever that means... : Can you give me some advice on how to proceed either with a local plumber or the wate company... : My neighbor is watering his lawn and smirking as I write this note for help...
| There are none. |
