Re: slow water out of tub's only , Thanx Terry
Posted by Dale on November 19, 1998 at 11:11:10:
In response to Re: slow water out of tub's only , Thanx Terry
Terry ,
thanks alot your a big help it's nice to know that there are people like you still out there to give a hand once in awhile . If your ever in Labelle , Fla. stop by at The Sweet Tooth Cafe' For a Good old fashion Banana Split on the house .
Thank Dale
: : Is that the peice that turns the water on and off
: : that is behind the handle . It has two other vavles one on each side , would I be able to shut the water off by them or at the main ?
: Shutting the water off at main is good. The part shown on the previous post is a Moen 1225 cartridge. Not knowing the tub faucet you have, it is only a guess. Some of the Moen single handle tub and shower faucets came with shutoffs behind the wall plate that could be turned off using a flat blade screwdriver. Terry
Replies to this post
