Re: Bathtub
Posted by hj on November 19, 1998 at 09:48:03:
In response to Re: Bathtub
I assume this is a fiberglass tub. If so then the surface has been worn away and you have the fairly porous sub surface visible. That will show the specified problems in a short time. The only good repair is to refinish or replace the tub.
: Hi
: Is there a possibility for bathtubs to develop soap scum or mildew stains faster that is, immediately
: 2 to 3 days after washing the tub?? Does it indicate that the tub has become old? If that's the case can
: anyone suggest a remedy for this other than replacing the tub?
: thanks,
: --Dharani
Replies to this post
There are none.
