| Posted by JUDY WOOD on August 02, 2001 at 23:06:26: | |
| In response to Re: Leaking Hot Water Heater | |
: MY WATER HEATER IS LEAKING FROM THE T & P VALVE.SO WHAT IS A EXPANSION TANK?? HOW DO I DO THIS? I HAVE REPLACED ABOUT THREE VALVE'S THINKING IT IS A FAULTY VALVE, THEN THOUGHT MAYBE I SHOULD JUST REPLACE THE WHOLE WATER HEATER. WHAT DO YOU THINK??? THANK YOU JUDY WOOD PURPLEDOT21@AOL.COM : Laurie Palmen : If your water heater is leaking from the bottom of the tank, replace the tank. If the tank is leaking from the T & P valve replace or add an expansion tank......Lou
| There are none. |
