| Posted by Joe B. Davis on July 12, 2001 at 13:18:45: | |
| In response to Re: Briggs Toilets | |
I also cracked the tank on my Briggs toilet by overtightening. 3M 4200 Fast Cure Marine Adhesive/Sealant, applied carefully but liberally to the INSIDE of the DRY tank, seems to have done it for me. Use a new tank-to-bowl gasket when reinstalling the tank. (You can get a set with gasket and all the following parts, except for two additional rubber washers.) When replacing the tank, be sure to use the following bolt arrangement for the bolts between the tank and the toilet bowl on each side: 1. Brass bolt inside 2. Rubber washer inside 3. Rubber washer outside 4. Stainless washer outside 5. Brass nut outside. Do NOT overtighten. 6. Bolts through toilet. 7. Rubber washer under toilet. 8. Stainless washer under toilet. 9. Thumbscrew tightened only enough to secure and level tank. : : Terry: : : Can I buy a replacement tank or do I have to buy a whole new toilet? : : Thanks. : : Bob from NJ.
| There are none. |
