Re: water softner causing low water pressure
Posted by brad on June 06, 2001 at 19:50:21:
In response to Re: water softner causing low water pressure
: I was hoping you might have some other ideas why my water softner would be causing low water pressure? When we switch it over to by-pass we have alot of pressure. We have cleaned all screens and also taken the valve apart and made sure it was clean and it all seemed to be in working order. We also use resin cleaner on a regular basis, so I am stumped as to the cause. If you have any other ideas please let me know. Thank you very much! your distrubuter tube is plugged up more than likley it is the tube going through the resin bed about a $20.00 fix if you do it yourself
Replies to this post
There are none. |
